DIAdem
Report 3D - Setting Color Palette
I'm creating a 3D plot and I want to set the color of the points acting as another axis. From what I can recall this can be done using the color palette. When I try this I get an error that the sud for this operation can not be found. I have attached a picture of the error.
(2,266 Views)
Hi BrianCT,
I tried this out on my end using DIAdem 2018 and the shipping example "D3-Map_ScalableBackgroundImage.TDR". I set the following:
Type: Points
Color: Palette....
Then I get the same error as you. I cannot replicate this when using other Types. Anyone else able to try on a different version of DIAdem?
(2,243 Views)
