DIAdem
Report - y axis names with 'n systems' plots
Using NSystemsMode set at e2DAxisNSystems I can create a plot in Report like below.  However, I am not able to change the y axis titles in a good way.  It appears that all plots take the same name (example: 'Plot name' in the picture) .  I would like that each plot has the y channel name of the curve as the axis title.  How can do this using script? I have not found a way to access each axis separately...
Any help is appreciated.
Thomas
(3,158 Views)
Accepted by topic author mrme
Hello Thomas,
If you enter the following string as the label for the Y-Axis, you should get the desired result:
@@ChnName(CurrChnNo)@@
This what I see in REPORT:
Please let me know if that helped,
Otmar D. Foehner
(3,137 Views)
Hi Otmar,
Yes, it worked.  I used your proposal in a line of script:-
objAxis.YAxis.Label.Text = "@@ChnName(CurrChnNo)@@"
Thank You!
Thomas
(3,129 Views)
