DIAdem
Report
I wrote a script that allows me to decrease the size of a text that is in the masterlayout of my report ('text5' in the image),  so I set two conditions for this, the first when The length of my text exceeds 29, the text decreases by 1, and when the length is greater than 29, the size takes the value 2.5. My problem is that once the decrease is made with the new value, the master layout registers this new value and so I can not return to the initial value, for example, if I have an initial size = 4 and That it becomes 3, thereafter I will have the value 3 which becomes 2 while I would still like to have again the size 4 which becomes 3. any ideas pease ? 😞
(3,385 Views)
Accepted by topic author say12
Hi say,
It sounds like you'd be better served with explicit character length ranges that correspond with absolute font sizes, something like this:
Chars = Len(Text5)
IF Chars < 29 THEN
  oCtrl.Font.Size = 4
ElseIF Chars < 35 THEN
  oCtrl.Font.Size = 3
ElseIF Chars < 41 THEN
  oCtrl.Font.Size = 2
ELSE
  oCtrl.Font.Size = 1
END IF
Brad Turpin
DIAdem Product Support Engineer
(3,348 Views)
Thank you.
Regards
(3,325 Views)
