DIAdem
Reports Data Plotting Problems
I am concatinating several files from data collected at 1hz.  There is often large time gaps between each file.  How can I have the plots not connect the lines between each file set.  It often makes the data look like it flat lined.
(3,214 Views)
Hi bm2cox,
The short answer is to insert a row of NoValues between concatenations.  I happen to be retooling my multiple file concatenating VBScripts which are posted on the web, and it occurred to me to add this as a parametrizable feature.  Could you send over an example set of data files?  If my VBScript works on them, I'll send it to you sometime today.
Brad Turpin
DIAdem Product Support Engineer
brad.turpin@ni.com
(3,205 Views)
