DIAdem
Resolution of WMF graphic file
Hi. If I save a graphic in DIAdem 2011 as WMF (via script command PicExport()), I get much better resolution as for the same graphic in DIAdem 2012. Can I get better WMF resolution in DIAdem 2012? How? In attachment both files.
(5,480 Views)
Hi Sasha,
Could you post the VBScript code you used in DIAdem 2012 and DIAdem 2014 to create these *.wmf image files?  DIAdem 2012 no longer offers *.wmf as an option when you interactively export to a picture file.  Have you tried the *.emf export option's resolution?  The "Extended Windows Meta File (EMF)" is the updated version of the older "Windows Meta File (WMF)" image file format.
Brad Turpin
DIAdem Product Support Engineer
(5,393 Views)
