DIAdem
Resultant calculation but result not same
I found one issue when I calculate the Resulatnt from head x, y, z acceleration data when I process the crash test data.
one computer XP system the result channel name  is : ResultantXYZ,
one conputer Win7 system the result channel name is : Res_from_XYZ
Who know why I have the different result channel name?
(4,776 Views)
Hi woshiyun,
That looks like a difference based on the DIAdem version.  We harmonized the standard resultant channel names many years back so that they would be the same regardless of whether they were created with an English operating system or a German operating system.  You can branch your code based on the ProgramRevision variable.
Brad Turpin
DIAdem Product Support Engineer
(4,702 Views)
Thanks for your reply.
I also get some support from local NI office, they said that is the compatibility issue setting in the Option->General..->Compatibility..->Neutral result channel names in analysis.
(4,700 Views)
