DIAdem
Round Function Error
i noticed an error in my script using the in-build Round() function. Why do these 2 statements output the same result (at least for me using DIAdem 2022 Q4):
Logfiledel
Logfilewrite Round(1.5) ' Output = 2
Logfilewrite Round(2.5) ' Output = 2 (?)
Is this a bug or what could be the problem? Obviously Round(2.5) should output 3 and not 2.
Thanks in advanced for your support!
(1,870 Views)
Microsoft follows IEEE 754 standard - round half to even.  So it is working perfectly to the standard.
(1,844 Views)
Thanks for your reply.
Is there an in-build function to round 'mathematically', which means:
  • round up from 0.5 <= x < 1 --> e.g. Round(2.5) = 3
  • round down from 0 <= x < 0.5  --> e.g. Round(2.4) = 2
(1,796 Views)
Accepted by topic author mt90354
The built-in rounding in VBS is just that one.
Some options:
1. Try:
Call LogFileWrite(FormatNumber(1.5, 0))
Call LogFileWrite(FormatNumber(2.5, 0))
2. You can implement your own logic for rounding
3. DIAdem has built in whole channel rounding:
You can record it to get the script with the needed options
(1,788 Views)
