DIAdem
Run Diadem from batch file with parameters
I use Diadem 2015 Advanced version for creating reports.
First I run batch file, and run Diadem with parameters from this batch file by command (e.g.)
"C:\Program Files\National Instruments\DIAdem 2015\DIAdem.exe" "cT4:='C:\work'" "cT5:='123'" "/cScriptStart('D:\StartScript.VBS')"
I need send many parameters from batch file to DIAdem and I use various  DIAdem variables (T, L, B).
All is OK, when lenght of this command is less than 520 symbols, and when lenght of command is bigger than 520 symbols DIAdem doesn't run.
How to resolve this problem?
Best regards.
(5,763 Views)
Accepted by topic author prophecy13
To avoid trouble using command line just switch to an alternative approach.
It is quiet simple to write vbs scripts using echo command.
@ECHO OFF
set STARTSCRIPT=%TEMP%\DIAdemBatchScript.vbs
echo ' Script to start DIAdem from batch > "%STARTSCRIPT%"
echo option explicit >> "%STARTSCRIPT%"
echo T4="C:\work" >> "%STARTSCRIPT%"
echo T5="123" >> "%STARTSCRIPT%"
echo ScriptStart("D:\StartScript.VBS") >> "%STARTSCRIPT%"
"C:\Program Files\National Instruments\DIAdem 2015\DIAdem.exe" "/cScriptStart('%STARTSCRIPT%')"
I would prefere this approach from any language because there are always limitations in length of command line options of any process.
It also helps debugging because you can run the script multiple times.
(5,721 Views)
Hi AndreasK,
You approach work for me.
Thank you.
(5,713 Views)
worked for me as well, thanks
(3,230 Views)
