DIAdem
SDK plugin will not open in Diadem 2019/2020
I am trying to use the LabVIEW DataPlugin SDK.  Using the asciioneshot and  binaryondemand examples included with SDK, I have created the dll and the installer in LABVIEW 2018 64 bit.  Using Diadem 2019 and 2020 64 bit, I get an error (Cannot Load the File).  Using Diadem 2018 both plugins load the file correctly.  Diadem 2020 lists both plugins under the DataPlugin Settings.  Any ideas on why the plugin isn't working in Diadem 2019 and 2020?
Ken
(2,263 Views)
Hi Ken_ge,
due to an update in the DataPlugin layer DIAdem 2019 and newer can no longer work with older LabVIEW DataPlugin versions. We are currently working on an update of the LabVIEW DataPlugin SDK for LabVIEW 2020 - which is going to address this issue.
Please let me know if you need a pre-release candidate for first tests...
-Stefan
(2,201 Views)
Hi Stefan,
   Thanks for this information about the DataPlugin layer.  I am just starting to try the LabVIEW DataPlugin, I can just use DIAdem 2018 until the 2020 SDK is released.  Once again Thank You.
Ken
(2,188 Views)
Hi Stefan,
I just ran into this same issue. Would it be possible to get the pre-release candidate?
-Daniel
(1,888 Views)
I can proudly announce, we have successfully released the new version of the LabVIEW DataPlugin SDK 2020 to the web:
https://www.ni.com/en-us/support/downloads/tools-network/download.labview-dataplugin-sdk.html#381650
Stefan
(1,642 Views)
