DIAdem
SUD link to VAS file
I'm having issues with the Dialog Editor recognizing user variables.  I recently added a variable to my VAS file, updated in Diadem by Edit>>Enable User Variables, but when I return to the Dialog Editor, it doesn't recognize the variable.  The variable works fine in Diadem Script, which is confusing.
All my user variables up to this point have worked fine, and the existing ones function properly when the SUD is executed, I just can't seem to get the Dialog Editor to recognize anything new.  I'm nowhere near the 1,000 variable maximum for a VAS file I found on another post.
Any suggestions?  I've tried different variable names, and I know my syntax is correct because it was working fine before.
(3,511 Views)
Never mind.  Problem fixed on reboot.  Closing and restarting Diadem never produced an error, but a complete shutdown flashed a Diadem application error before powering down.
(3,507 Views)
