DIAdem
SVD ?
I would appreciate some help with the following problem. I have a number of 3D space points that I would like to fit a straight line through. The solution to the problem has mentioned to be SVD in this article: https://www.codefull.org/2015/06/3d-line-fitting/
What is the equivalent of linear regression in 3D space and how can that be done in Diadem?
Thanks in advance,
Tim
(2,790 Views)
 My name is Jaimie, I'm an Applications Engineer at National Instruments.
From what I understand you're trying to find the line of best fit through a number of points in a 3D space. This would be linear regression in 2D, from looking into it, it seems the equivalent to this would be a 3D Orthogonal Distance Regression (ODR) line. I have included the link to a page explaining this:
Line of Best Fit For Points in Three Dimensional Space
http://mathforum.org/library/drmath/view/69103.html
I can't find an example on this and I believe this would be quite complicated to implement in Diadem. Could I ask why it is that you'd like to have a straight line through through some 3D space points and I may be able to find an alternative solution for you?
Thank you,
Jaimie
(2,749 Views)
