DIAdem
Sample Flexray bus log files + Fibex .xml bus log database files needed
I am working on developing a significantly simpler bus log conversion dialog than the one that DIAdem has.  It will automatically derive the valid bus numbers (between 0 and 255), and eIdMode (eDbFileIdModeDEFAULT or eDbFileIdModeNMea2000) for a set of bus log files and databases within a folder and then bus log convert them all.  This capability will be added to the existing free Bulk Import app I developed.  The DIAdem app is nearly complete.
For testing purposes, I am in need of some small Flexray bus log files, and the associated bus log database file .xml Fibex format.
If anyone is kind enough to share them with me, please indicate if they are proprietary, or if they can be shared with the community (as samples with the app).  You can post them in this forum if sharable, or email them to me at markwkiehl@gmail.com (or by DropBox negotiation after contact) if proprietary.
Thank you in advance.
(2,968 Views)
Accepted by topic author markwkiehl
A few days ago I stumbled upon a DIAdem help page that mentioned FlexRay bus log and database files. I found the sample data in:
Program Files\National Instruments\DIAdem 2020\Libr\Data\
named:
FlexRayExample.tdms
FlexRayExample.xml
I bus log converted them using the following setting:
Log file type: NI XNET (TDMS)
Log database file: FlexRayExample.xml
BUS No. 1
Bus Type: Fibex Database file (*.xml)
Fibex database cluster: FlexRay_Cluster
(options are: "CAN_Cluster","CAN_Demo_Box_Cluster","FlexRay_Cluster")
(2,739 Views)
