DIAdem
Save multiple data independent
Can you tell me if it is possible to save data from multiple channels, each channel with a different save trigger?
I have a cycIing machine and I need to record data from 6 channels, (that are not synchronized - different part of cycling for each channel), and to save data just when the data passed a certain value, for an among of time.
Please tell me if it is possible in Diadem, and what blocks should I use.
Thank you for the support.
(5,489 Views)
Hello Marse,
Yes, that is possible. The attached example shows a data acquisition with simulated signals and two different clock rates. Saving data starts at a certain slope level for a certain number of values. But this is just one possible way to solve your request.
Greetings
Walter
(5,469 Views)
Thank you for the response, but I have Diadem 10.2 and if I want to load your DAC, I receive the message : "File-error.(Version is incompatible)".
Could you make the DAC available for the Diadem 10.2?
And I want to add that the values from the channels are not synchronized, and when I need to record the data from the channel 1, maybe I don't need to record the data from the channel 2, or 3... and so on.
Thank you.
(5,466 Views)
Hi Marse,
Here is a version for DIAdem 10.2
Greetings
Walter
(5,424 Views)
