DIAdem
Script for getting a single point of data from a timed set
I have a set of timed data (Time vs. Resistance). This data set is 5 minutes long but I want to take that data and pull a single value from it. So I'd like to reduce that timed data set to a single point at the 2 minute mark.
I realize this should be implemented on the TDMS logging side, but is there a function that will do this within Diadem?
Kellen
(2,830 Views)
Hi Kellen,
If you're looking to extract a single point of data from your entire dataset, you should be able to index a channel through the Value property of the data channel itself. However if you're looking to perform some sort of averaging on the dataset, you can use the Descriptive Statistics function in the Statistics Palette of your ANALYSIS panel:
Descriptive Statistics Dialog
Let me know if you are looking for something else or if you have any questions about implementing the above!
(2,773 Views)
