DIAdem
Scripting MathScript
Calling MathScript functions does not seem to record using the macro record function. Is there a way to call MathScript functions in the scripting interface?
Steve.
(4,119 Views)
Accepted by topic author St3ve
Hi St3ve,
I haven't done this myself, but the Help system says:
"When you create or modify a MathScript, DIAdem creates a compiled
LabVIEW VI that has the same name as the MathScript and is preceded
by the text DIAdem_MathScript_, on the SCRIPT user path."
Can you find such a "DIAdem_MathScript_..." VI in your Script User Path?
Brad Turpin
DIAdem Product Support Engineer
(4,099 Views)
Brad,
Many thanks, I was a bit trigger happy writing that post. I subsequently discovered the same help  document.
Apologies,
Steve.
(4,076 Views)
