DIAdem
Searching files containing multiple channels
As stated in the help entry "Evaluating Search Conditions (DataFinder)"
the following DataFinder advanced search will never yield results:
C1 Channel Name = MyChannel1
C2 Channel Name = MyChannel2
C1 AND C2
But how would I actually search for files that contain both MyChannel1 and MyChannel2?
(which clearly is the intention of people trying above snippet)
(5,372 Views)
Well, in the end you have to apply a script to calculate the intersection of the two (or multiple) searches. Run the script below (or use attached file) after each search (for files) to create the wanted intersection:
option explicit
Dim filePathColumn : Set filePathColumn = Navigator.Display.CurrDataFinder.ResultsList.Columns.Add(eSearchFile, "fullpath")
Dim firstSearch
If Not Data.Root.ChannelGroups.Exists("SearchResults") Then
  Call Data.Root.ChannelGroups.Add("SearchResults").Activate()
  firstSearch = true
Else
  Call Data.Root.ChannelGroups("SearchResults").Activate()
  firstSearch = false
End If
Dim loadedChannel : Set loadedChannel =  Navigator.LoadProperty ("fullpath", Navigator.Display.CurrDataProvider.ResultsList.Elements)(1)
Call ChnMultipleSort(loadedChannel,"",1,1)
If firstSearch Then
  loadedChannel.name = "intersection"
Else
  Dim intersecChannel : Set intersecChannel = Data.Root.ChannelGroups("SearchResults").Channels("intersection")
  Dim iChnLength : iChnLength = intersecChannel.Size
  Dim i : For i = iChnLength To 1 Step - 1
    If NOT FindInChannel(loadedChannel, 1, loadedChannel.Size, intersecChannel.Values(i)) Then
      Call DataBlDel(intersecChannel, i, 1)
    End If
  Data.Root.ChannelGroups("SearchResults").Channels.Remove(loadedChannel.name)
End If
Function FindInChannel(channel, first, last, wanted)
  FindInChannel = false
  Dim comp
  If first > last Then Exit Function
  If first = last Then
    comp = StrComp(channel.Values(first), wanted)
    If comp = 0 Then FindInChannel = true
    Exit Function
  End If
  Dim middle : middle = (last + first) \ 2
  comp = StrComp(channel.Values(middle), wanted)
  If comp = 0 Then
    Exit Function
  End If
  If comp = -1 Then
    If middle = first Then middle = last
    FindInChannel = FindInChannel(channel, middle, last, wanted)
  Else
    FindInChannel = FindInChannel(channel, first, middle, wanted)
  End If
End Function
(5,355 Views)
