DIAdem
Select Byte Order when Savin a DAT file
I need to save a DAT file selecting "Low -> High" as Byte Order, but nothing works. Doesn't matter what I do It's always stored as "High -> Low"
I tried assigning the value "Low -> High" to the variables FileHdByteOrder & DataSetByteOrder but when saving the values return to "High -> Low" and are ignored.
Is there a way to do it?
Thanks in advance.
Marc.
(5,469 Views)
Hi Marc,
I don't think you can change that behavior.  My understanding is that DIAdem will always write Little-Endian, and the ByteOrder flag is for reading only.  What program only supports Big-Endian reading of DIAdem *.dat files?!
Brad Turpin
DIAdem Product Support Engineer
(5,412 Views)
Hi Brad,
Thanks for the clarification.
We generate the DAT files with LabVIEW (any byte order can be selected) and then we use a custom Java application to manage a database results from the DAT files.
Sometimes we need to work on the files using DIAdem but gives us many problems as our Java application only supports Big-Endian DAT files. I think that we will have to implement that feature in our application.
Any way could be nice to select the byte order in DIAdem.
Marc.
(5,397 Views)
