DIAdem
Select a list of data
I need to print out a list of acquisition data in a report.
I have a for loop in which every iteration I want to read one data, update the report and then print the report.
Question: How I can select these data which format is a string like
MP1
MP2
MP3
Is it possible to define a varaible that is a sum of a string radix (MP) and a number (1) which encrease each iteration of the loop?
Marco
(4,399 Views)
Hello Marco!
You can build a string out of another string and an integer in VBS just with a + operator or better the & operator: Have a look at this example:
Option Explicit
Dim i
Dim Filename
For i=1 To 3
  Filename = "MP" & i & ".tdm"
  Call DataFileLoad(Filename,"TDM","Load")
Hope this helps
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,397 Views)
Thank you Matthias,
I still have problem in defining the folder from which the data are loaded.
Should I define another variable before the for loop?
How can I set the path in the following command?
Best regards
Marco Milan
(4,372 Views)
Hello Marco!
Two possible solutions. You can change the DIAdem variable DataDrvUser and set it to your path or you can use a variable in the code and use a full qualified filename (what I would prefer). This is the code:
Option Explicit
Dim i
Dim Filename
Dim Path
Path = "C:\MyData\"
For i=1 To 3
  Filename = Path & "MP" & i & ".tdm"
Matthias
Matthias Alleweldt
Twigeater?
(4,369 Views)
