DIAdem
Select folder to save from Dialog editor
Trying to specify the folder to save the output file.
Using  MSCommonDlgAX activeX control and the below code behind the browse button. But I can specify only files but not folders.
Sub FilterBrowse_EventClick()
Dim This : Set This = FilterBrowse
 MSCommonDlgAX.X.ShowSave
 FilterFilePath.Text = MSCommonDlgAX.X.FileName
End Sub
Some please help in opening the windows explorer and choose the folder/Directory to save from Dialog Editor.
Rsh
(6,062 Views)
dim newfilepath
If  (PathNameGet("ANY",,,,,,"Select the directory to save the new files into:") = "IDOk") Then
  newfilepath=FileDlgDir
else
End If
(6,058 Views)
This DIAdem command will open open the directory selector.
Option Explicit
dim initPath : initPath = "C:\"
if "IDOk" = PathDlgShow("Please select Path", initPath) then
  MsgBox OutPutPath
end if
Greetings
Andreas
(6,048 Views)
