DIAdem
Select multiple folders and store in array: type changes from folder object to string?
I am trying to implement the following:
The user selects a folder (which contains subfolders) in a dialog:
Set Dateiauswahl = CreateObject("Shell.Application").BrowseForFolder(0,"Verzeichnis auswählen",512,mess_path)
Set Ordner = CreateObject("Scripting.FileSystemObject").GetFolder(Dateiauswahl.Self.Path)
All subfolders in the selected folders are listed in two global array variables:
Call GlobalDim("FolderList("&Ordner.SubFolders.Count - 1&")")
Call GlobalDim("FolderPaths("&Ordner.SubFolders.Count - 1&")")
f=0
for each Unterordner in Ordner.SubFolders
    FolderList(f) = Unterordner.Name
    FolderPaths(f) = Unterordner
    f=f+1
next
Later on, only the files from some of the subfolders should be stored in another array FileList:
f=0
    for q=0 to UBound(auswahl)
       Unterordner = FolderPaths(auswahl(q))
       Call MsgBox(Unterordner)
       For Each File In Unterordner.Files
           if instr(1,File.Name,"Speed")=0 then
               FileList(f)= File.Path
               f=f+1
           end if
next
Now I seem to have a problem with the type of the data that is stored in the FolderPaths array. While Unterordner is a Folder Object, and needs to be a Folder Object for For Each File In Unterordner.Files to work, storing it in the array turns it into a string variable.
I don't really understand why, and am looking for a solution so that I can extract single subfolders from the FolderPaths array and then extract their files.
(5,665 Views)
Accepted by topic author maliya
Hi maliya,
In order to assign an object to an array element (or any other variable), you must use the Set syntax, like this:
Set FolderPaths(f) = Unterordner
Then later on you can retrieve it with the same syntax:
Set Unterordner = FolderPaths(auswahl(q))
Brad Turpin
DIAdem Product Support Engineer
(5,641 Views)
what i found out is, that the order of the folders sometimes is mess - and i don´t know exactly why or on what the order depents.
it can be that your list is
c:\tmp\2
c:\tmp\1
c:\tmp\6
c:\tmp\3
to get the list in the right order i use a "bubble-sort"........
bubbleSort(Array A)
  for (n=A.size; n>1; n=n-1){
    for (i=0; i<n-1; i=i+1){
      if (A[i] > A[i+1]){ A.swap(i, i+1)
      } // ende if
    } // ende innere for-Schleife
  } // ende äußere for-Schleife
(5,588 Views)
