DIAdem
Send data from event to SUD Dialog
I have a script that trigger an event function ( OnCursorChanged)
and i want that each time the event is triggered ,send a string to my Dialog (contains list box of string ).
how could i do that?
thanks
(5,338 Views)
maybe this will work, you must start your dialog non-modal and can use the CustomAction-Event in the dialog:
Sub OnCursorChanged-SUB
Dim myDlg
Dim sDialogCode : sDialogCode = "theNameOfYourDialogCodeProperty"
  If Nothing is SudNonModalDlgLst(sDialogCode ) Then
    Set myDlg = SUDDlgCreate(sDialogCode , sITMPath & "test2.SUD")
    Call myDlg.Show()
  Else
    Set myDlg = SudNonModalDlgLst(sDialogCode )
  End If
  Call myDlg.RunCustomAction
End Sub
(5,333 Views)
Hi MartinKozlowski
Maybe the Example in DIAdem "User dialog boxes in DIAdem-VIEW" could also be helpfull. Open Help>>Examples and then open the book "View and edit data"
Hope this helps
Winfried
(5,327 Views)
