DIAdem
Set Diadem 2018 as default program for .VBS files
Hello Diadem users,
I just have installed Diadem 2018 along Diadem 2015. I tried set Diadem 2018 as default program for opening all related files (.dat, .tdms, .tdv, .sud, and so on ). I mannaged to set all of then expect of one, .VBS. Every time I open a script, it opens in Diadem 2015. I tried to changed that in "Default programs" but the .vbs file is missing in the options. Have any of you met with this issue ?
(2,696 Views)
If you want it to be connected just press
Shift+Right klick
on a vbs file.
Choose
Open with
in context menue.
Choose another app
browse to DIAdem and select to always open using DIAdem.
Comment: The registration was dropped, because it overwrites the windows default to run vbs files using the windows scripting host.
(2,680 Views)
Hi Andreas
That was my frist call. When i choose Diadem 2018 and opend the file it opens Diadem 2015 instead. Is there any other workaround ?
(2,646 Views)
HKEY_CLASSES_ROOT\.vbs\OpenWithProgids
HKEY_CLASSES_ROOT\DIAdem.VBS.15.0
If you open regedit you can pimp your registry to match your needs.
Thats what I did.
(2,640 Views)
