DIAdem
Single Channel Excel Export
I want to write a VBScript that will export only selected channels to an Excel file, similar to what is done manually with the Excel Export Wizard.  Is there a function (possibly using the EXCELExpChn variable) that will allow me to do this?  I can not use a saved configuration file, because the total number of data channels and the channels to be exported will be variable.
(3,462 Views)
Please have a look at the following forum entry which explains how to select channels to export them :
http://forums.ni.com/ni/board/message?board.id=60&message.id=4997
Please ask if you have further questions.
Andreas
(3,441 Views)
