DIAdem
Sort channel
Hi
I have following Channels Group names:
Max Freq Offset
Freq Drift
Freq Drift Rate
Max Freq Offset1
Freq Drift1
Freq Drift Rate2
And when I am using the Sort Channel script:
C:\PROGRAM FILES (X86)\NATIONAL INSTRUMENTS\DIADEM 2014\Examples\documents\SortChannelGroups.vbs
Then It doesnt sort it correctly.
But If i rename the test names instead from Freq Drift Rate to Freq DriftRate then it work properly.
Regards
René
(4,435 Views)
Hi Rene,
Please describe the type of sorting you're looking for.  You listed the starting pre-sorted state but not the desired ending post-sorted state.
Brad Turpin
DIAdem Product Support Engineer
(4,403 Views)
Hi
It is working now
(4,394 Views)
(4,389 Views)
