DIAdem
Specific channel to the data portal
Hi I am New to the Diadem community,
need support on the following thing
In Diadem how to bring the specific channels from the data store to data portal.
Example
in Data store navigated to the database and now approx 10 result showing, is the list having N number of channel, but i need to select only specific channel and bring to data portal.
Kindly help on this - thank in advance
Message 1 of 8
(1,859 Views)
Hi Paul,
As test I have opened the "ASAM Browse Settings Example" via a data store, a screenshot is attached.
You can search for results and import the results into the data portal by:
  1. Right-Click on the channel and select "Load Data"
  2. Drag and Drop as it is done with search results in the results of a MyDatafinder Query
Message 2 of 8
(1,818 Views)
Hi ColinF,
Very Sorry i believe i didn't ask the exact query.
I need this to be done in script vbs.
For example if i have 10 groups in all groups i need two channels named as "Speed" & "Time" that to be popped into data portal.
Scenario:
Group 1
            Time
            Speed
            ............N
Group 2
           Time
           Speed
           ..............N
Result required in Data portal.
Group1
            Time
             Speed
Group2
             Time
              Speed
This is how i need for N number of groups in VB script.
Kindly do needful.
Message 3 of 8
(1,809 Views)
Hi Paul,
if you use as an example the data store "ASAM Pass Fail Analysis Example 2023"  then you will see that all of your groups include the two first entries Temp_A and Temp_B. According to what you described the following script loads the two entries from every group into the data portal under an extra defined group for each group of the data store.
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim oMyDataStore, MyGroupList, MyTempAList, MyTempBList, name, i, Group
Call Data.Root.Clear()
Set oMyDataStore = Navigator.ConnectDataStore("ASAM Pass Fail Analysis Example 2023")
Set MyGroupList = oMyDataStore.GetElementList("Measurement", "" )
Set MyTempAList = oMyDataStore.GetElementList("MeaQuantity", "name=Temp_A" )
Set MyTempBList = oMyDataStore.GetElementList("MeaQuantity", "name=Temp_B" )
i = 0
For Each Group in MyGroupList
name = Group.Properties("name").Value
Data.Root.ChannelGroups.Add(name, i+1).Activate()
Call Navigator.LoadData(MyTempAList.Item(i+1), "Load", Nothing)
Call Navigator.LoadData(MyTempBList.Item(i+1), "Load", Nothing)
i = i + 1
Message 4 of 8
(1,794 Views)
Hi ColinF,
Thats great working perfectly. I have additional requirement on this. If its ok do needful if i want to post as a separate one let me know.
Example:
Main Group1
           Sub Group1
                              Flood
                              Water Level
                              Pressure.....n
          Sub Group2
                              Flood
                              Water Level
                              Pressure.....n
          Sub Group3
                              Flood
                              Water Level
                              Pressure....n
Main Group2
           Sub Group1
                              Flood
                              Water Level
                              Pressure......n
          Sub Group2
                              Flood
                              Water Level
                              Pressure.....n
          Sub Group3
                              Flood
                              Water Level
                              Pressure....n
Main Group3
           Sub Group1
                              Flood
                              Water Level
                              Pressure.....n
          Sub Group2
                              Flood
                              Water Level
                              Pressure.....n
          Sub Group3
                              Flood
                              Water Level
                              Pressure......n
Out Put Required:
Main Group 1
                     Sub Group 1
                                        Flood
                                        Pressure
                     Sub Group 2
                                        Flood
                                        Pressure
                     Sub Group 3
                                        Flood
                                        Pressure
Main Group 2
                     Sub Group 1
                                        Flood
                                        Pressure
                     Sub Group 2
                                        Flood
                                        Pressure
                     Sub Group 3
                                        Flood
                                        Pressure
Main Group 3
                     Sub Group 1
                                        Flood
                                        Pressure
                     Sub Group 2
                                        Flood
                                        Pressure
                     Sub Group 3
                                        Flood
                                        Pressure
Kindly help me out if any example available for inside diadem please let me know i will follow from that.
Thanks in advance.
Really your support helping me a lot.
Tones of thank you.
Message 5 of 8
(1,775 Views)
Hi Paul,
I just oversaw that you would like to have three levels also in the data portal.
The point is here, that the data portal can just have one root element and after that you can add channelgroups and channels.
So the structure you would like to have as an additional requirement is not possible in the data portal.
You can just have one Main Group = root element and different sub groups = channelgroups and Flood, Water etc = channels.
Message 6 of 8
(1,761 Views)
Hi Colin,
I modified the given script as below.
i am trying to load only the groups from this particular main group alone TR_M17_QT_32-1
which have two sub groups QT_32-1_Upper & QT_32-1_lower. its ouput coming, how ever its bring, but the code taking all the main group and providing the output.
Can you please look this and give me some solution. is some loop function i am making mistake.
Dim oMyDataStore, MyGroupList, MyTempAList, MyTempBList, name, i, Group,MyGroupList1
Set oMyDataStore = Navigator.ConnectDataStore("ASAM Pass Fail Analysis Example 2020")
Set MyGroupList = oMyDataStore.GetElementList("TestRUn", "name=TR_M17_QT_32-1" )
if MyGroupList.Item(1).Name = "TR_M17_QT_32-1" then
Set MyGroupList1 = oMyDataStore.GetElementList("Measurement", "" )
For Each Group in MyGroupList1
i = 0
i = i+1
end if
Message 7 of 8
(1,710 Views)
Hi Paul,
I made the change in the example code to reflect your requirement.
I know it is not the best code, but it is working.
Set MyGroupList1 = oMyDataStore.GetElementList("Measurement", "name=QT_32-1*" )
i = 0
i = i+1
Message 8 of 8
(1,679 Views)
