DIAdem
Speed of operation
I have current data from a motor with multiple stops.  The stops are indicated in high current spikes within the data channel.  The data was collected over 2 minutes.  How do I write a script to find the current spikes and return the time between each spike?
(5,536 Views)
Hi vloveday,
If you submit an example data set to this forum or my email (brad.turpin@ni.com), I'll look into it and make recommendations and/or send you example code to help you along.
Brad Turpin
DIAdem Product Support Engineer
(5,515 Views)
Hi vloveday,
Here's a VBScript that does what I think you're asking for.
Brad Turpin
(5,475 Views)
