DIAdem
Split a channel at specified point not by value
I want to split a channel There is found one command ChnSplitAtValue but it takes the value where you want to split the channel. I have data which has sinusoidal behaviour and i need to cut it at specified time or say 100th point onwards. How to do that.
Whereas ChnSplitatValue function keeps on picking the very first value it encounter in channel.
(3,737 Views)
Accepted by topic author GDU
Hello!
You can use the DataBlCopy command to copy the two parts into new channels.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,734 Views)
