DIAdem
Standard script layout modification
I would like to change the standard script layout format that appears every time I create a new script. Currently it's the DIAdem default:
'-- VBS script file
'-- Created on 17/10/2019 11:32:46
'-- Author:
'-- Comment:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
And I would like something like this:
'! @details ___.VBS script file
'! Description: ___
'! @author franco__
'! @date 17/10/2019 11:32:46
Option Explicit
Thanks a lot
(3,707 Views)
Hi franco,
To my knowledge there is no configuration to change the "letterhead" of a new VBScript in DIAdem.  We could create a custom button or perhaps overload the existing "New" button in the SCRIPT panel with a custom VBScript.  Then you could put whatever "letterhead" you want in the VBScript.  We'd have to programmatically create the new *.VBS file first with the FileSystemObject, say, then programmatically load it into the SCRIPT panel with the AutEdFileOpen() command.  So either create it in a standard starting folder or a temporary folder.
Brad Turpin
DIAdem Product Support Engineer
(3,636 Views)
