DIAdem
Starting a Python Script not possible
when I try to start a Python script with the Button with the arrow below nothing happens. It only works if the script is called via another little vbs script. Is there a solution to this problem?
Info: I got DIAdem 2021 SP 1 Script version
This is not critical as I have that workaround described above, but I did not find another place to report this issue.
Greetings
codingeric
Message 1 of 1
(1,443 Views)
