DIAdem
Statistics in Diadem
Hello everyone,
I have a problem with statistics and respectively histogram generation from a set of data
Below you can see  how my data channels look like.
In DIAdem VIEW I have ->
<All Channels>
Name  |Ch1 Dev1|Ch2 Dev1|Ch3 Dev1|Ch1 Dev2|Ch2 Dev2|Ch3 Dev2|Ch1 Dev3|Ch2 Dev3|Ch3 Dev3|
Number |1             | 2            |3            |4             |5             |6             |7            |8             |9             |
Length  |3             | 3            |3            |3             |3             |3             |3            |3             |3             |
Unit     | V            | V            | V           | V            | V            | V            | V           | V            | V            |
Channel contents
1         | 1.52      | 1.51       | 1.53       | 1.52       | 1.55       | 1.51       | 1.50     | 1.53        | 1.55       |
2         | 1.62      | 1.61       | 1.63       | 1.62       | 1.65       | 1.60       | 1.62     | 1.67        | 1.65       |
3         | 1.52      | 1.51       | 1.53       | 1.52       | 1.55       | 1.51       | 1.50     | 1.53        | 1.55       |
What I need is to create a histogram for a given row ->in this case number 2
It this straight forward or should I make some adjustments before that?
I hope my question is clear and is easy to follow.
Thanks in advance to anyone who can propose a working solution.
Message 1 of 8
(5,301 Views)
in the histogram generation function in Diadem Analysis you can choose how many classes you need.
The other settings can be left to automatic. Then you get 2 result channels SampleCount and ClassMean. Class Mean
are the classes and SampleCount is how many values are in every class.
In my case I choosed 5 classes and the result diagram is attached. You can see that most values are in class 1.62
Regards
DianaS
Message 2 of 8
(5,281 Views)
Hi , thanks for the fast reply.
When I start the Histogram generation from DIAdem analysis, the first thing I see as a problem is that I can choose only one
channel, under "Channels to be classified:".It is a major one, because the row I want to analyse is consisting of single values ,
spun over  9 channels. I've checked your solution, but it doesn't work for me so far.I can generate histogram for a single channel
without problems , but the values are spread in more channels.
Message 3 of 8
(5,277 Views)
In this case I suggest to combine the 9 channels to one.
Regards
DianaS
Message 4 of 8
(5,265 Views)
Regards
DianaS
Hi DianaS,
I tryed copying  but I didn't manage to copy single values - instead I copy all the channels with all values which is not what I want. Is there a way to copy a row in DIAdem view and convert it to column(channel)? excel can do that I really doubt that DIAdem can't.
Message 5 of 8
(5,255 Views)
Accepted by topic author fscommand
Hi
you can do this in a scipt.
Clear the dataportal, load the attached .tdm file and run the following script:
Dim i
Call ChnAlloc("Result", 3, 1,DataTypeFloat64,"Numeric")
for i=1 to 3
CHD(i,"Result") = CHD(1,i)
Then all the single values from the 3 channels will be copied to the result channel.
Regards
DianaS
Message 6 of 8
(5,239 Views)
Hi DianaS,
thanks a lot, that really solves the problem!Smiley Happy
Have a nice day and a sunny weekend.
PS:What if I want only even or odd values to be picked up ?
Message 7 of 8
(5,231 Views)
This will work for odd numbers:
Dim i
Dim a
a=1
for i=1 to 3
if CHD(1,i)mod 2 <> 0 then
CHD(a,"Result") = CHD(1,i)
a=a+1
end if
And this for even numbers:
Dim i
Dim a
a=1
for i=1 to 3
if CHD(1,i)mod 2 = 0 then
a=a+1
end if
Regards
DianaS
Message 8 of 8
(5,224 Views)
