DIAdem
Step-into subroutines issues; DIAdem debug mode
DIAdem debug mode doesn't step into the called subroutuines and remains in the main portion of the script when executing step-into.  Does DIAdem have the capabilities to step into subroutines?
I have both the main file and the file with the subroutine open and have even tried putting all the subroutines in the same file but still doesn't step into.
(2,807 Views)
Hi MD43,
This capability does exist in DIAdem -- make sure you're doing the following and it should step into any subprocedure that is called in the main code:
1.)  Ensure that the subprocedure is called in the main portion of the code.  If it is not called, you cannot step into it using the debugging tools.
2.)  Place a breakpoint one line after the "Sub <FunctionCall()>" line.
3.)  Run the debugger.  You should be able to step into the code from there.
When I reproduced this, I had everything in the same script (both the subprocedures and the calls to them).
Matt | NI Systems Engineering
(2,768 Views)
