DIAdem
Store results of ChnFiltCalc in original channel
I have acceleration data in several Groups.  Each Group has 15 channels.  I wish to apply a low filter to all channels in all Groups.  How do I go about storing the results in the original channels instead of having new channels created?
Here is my code...
Dim iGroupCount, i
For  iGroupCount = 1 to GroupCount
     Call  GroupDefaultSet (iGroupCount) 'sets the current group as the default
       For i = 1to15
       CallChnFiltCalc("","["& iGroupCount &"]/[" & i & "]","","IIR","Bessel","Low pass",2,100,0,0,1.2,25,"Hamming",1,0
Thanks!
Doane
(4,605 Views)
Hi DBuksar,
The 3rd parameter of the function call specifies the result channel R of the calculation:
Call ChnFiltCalc(XW, Y, R, FiltStruc, FiltStyle, FiltType, FiltDegree, FiltLimit, FiltLowLimit, FiltUppLimit, FiltWave, FiltSamples, FiltWndFct, FiltZeroPhase, FiltCorrection)
Thus it should be sufficient if you use your second parameter also as the third parameter instead of leaving it empty:
CallChnFiltCalc("","["& iGroupCount &"]/[" & i & "]","["& iGroupCount &"]/[" & i & "]",...
Hope this helps,
Ralf
(4,595 Views)
Thanks Ralf.  That did the trick.
(4,583 Views)
