DIAdem
Streaming to a TDMS File In DIAdem
Is there a way in DIAdem to stream signal data to a TDMS file, instead of to a TDM file?  I have DIAdem DAC, and DIAdem Advanced (so I can write scripts) and would really prefer to keep these files consistent with other TDMS files from other sources without a lot of custom code.  All the descriptions talked about DIAdem being able to save to TDMS, and I thought that would be stock out-of-the-box functionality.
(2,553 Views)
Hi Steveh01,
I'm sorry. Saving signals with DIAdem DAC directly to disk is only possible in TDM (or the old DAT format). The only option you have is loading the TDM file and save it to TDMS.
Greetings
Walter
(2,495 Views)
