DIAdem
Subtract a constant from values in a channel?
I am certain that this is not a difficult task, yet I the answer seems to be eluding me. I have a large number of channels, and I merely need to offset each channel by its respective initial value.  Since the channels are all named, I am having difficulty referencing the channels without an error.  Any assistance with writing this script would be greatly appreciated.
Ray Foltz
Message 11 of 14
(1,888 Views)
Hello Ray!
I hope this script will solve your task:
Option Explicit
Dim i
Dim j
Dim n
For i=1 To GroupCount
  For j=1 To GroupChnCount(i)
    n = CNo("[" & i & "]/[" & j & "]")
    Call FormulaCalc("ch(" & n & ") := ch(" & n & ") - chd(1," & n & ")" )
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 12 of 14
(1,883 Views)
I know this thread is 10 years old, but it is still the first google result for "Diadem subtract by scalar". An alternative (an easier for me) method to do this is use the 3D Arithmetic channel functions and use Matrix-Scalar. Select your desired channel as the 1D matrix, enter the scalar (pay attention to the scalar's sign for subtraction), select where you store the result. Complete.
Message 13 of 14
(995 Views)
Hi George,
To subtract a constant value from a channel.
Analysis, basic functions  Offset correction. This will do add or subtracts from all values in a channel.
to multiply use the function next to it  Scale a channel.
Paul
Message 14 of 14
(994 Views)
