DIAdem
Summation of two channels or more
What is the way to do the Summation of 2 channels or 4 channels?
My formula is
Channel1
channel2
channel3
channel4
TD= (SUMation (Ch1 and Ch2)) / (Sumation (Ch1 and Ch2 and Ch3 and Ch4))
Thanks!!!
Sara
(3,981 Views)
Hi Sara,
Do you want to add arrays element by element:
ArrayOne(1) + ArrayTwo(1)
ArrayOne(2) + ArrayTwo(2)
ArrayOne(N) + ArrayTwo(N)
Or do you want to sum all the elements of one array and then add that to the sum of all the elements of the other array?
In both cases you can do this in the ANALYSIS panel of DIAdem.  For the first case above you can use the Basic Mathematics palette of ANALYSIS functions (Add, Divide).  For the second case above you'll need to use the Statistics palette of ANALYSIS functions to calculate the sum of each channel.
Brad Turpin
DIAdem Product Support Engineer
(3,970 Views)
Hi Sara,
    You can use the following expression:
Call Calculate("Ch(""[1]/prueba"")=Ch(""[1]/Speed"")+Ch(""[1]/Torque"")+Ch(""[1]/Revs"")",NULL,NULL,"")
    I've used the Example data which is loaded in Data Portal by default when launching DIAdem.
David Oña
(3,940 Views)
