DIAdem
Superscript in PDF report extends to the previous line
Hello everyone,
In our PDF report, we mark the information we obtain from our customers with an "a" in superscript in front of a text. The problem is the superscript a crosses upper line and extends to the previous line which doesn't look nice (see picture, screenshot of PDF report at 128%). The superscript is written as
^ha^n
One solution to solve it would be to enlarge the lines, but then the page won't fit all the information we need. Is there maybe settings to lower the superscript a bit? I couldn't find it anywhere. Or other solution at all?
Thank you very much
Marek
(1,505 Views)
Accepted by topic author MarekNebyla
Maybe using a unicode character might work.
ª Custom
Just copy and paste the character from above.
If you work with script you need to make sure your script is unicode or use ChrW method.
MsgBox (ChrW(&h00AA) & " Custom")
You will find charaters like this using "Windows Character Map".
(1,470 Views)
Thank you very much, AndreasK!
It works again. I used the Ctrl+C, Ctrl+V method.
Marek
(1,454 Views)
