DIAdem
Suppress dialog when closing DIAdem
How can I suppress or quit the dialog box that comes up when closing DIAdem if data or layouts have been modified via SCRIPT ?
I tried:
  CmdNoDialogDisp = TRUE
  CmdNoWarningDisp = TRUE
  CmdNoMsgDisp = TRUE
  CmdNoErrorDisp = TRUE
  CmdNoInfoDisp = TRUE
without success.
(6,192 Views)
Accepted by topic author Phex
Hello Phex,
Have you tried using the "FileModification" variable?
It can be accessed in the General Settings dialog in DIAdem from the menu. Please go the "Settings > Options > General ..." menu to change it manually, then save the "desktop.ddd" configuration file to make the change permanent.
You may of course also set the variable "FileModification = ignore" in a Script to get the same effect.
Hope that helps,
      Otmar
Otmar D. Foehner
(6,180 Views)
Wonderful! FileModification = "ignore" is exactly what I was looking for!
Thanks Otmar.
(6,174 Views)
