DIAdem
Sync 3D model with data- rotation model
I am trying to sync my 3d model with my data - one channel of time and 3 channels of value - x,y,z dimensions.
I have looked on the example to understand how to do it but no success.
I attached my 3d model and my data .
Thanks and waiting for reply
(5,700 Views)
the 3D model file
(5,694 Views)
Hi OzShimon,
What problem are you having with displaying your data on the 3D model? Were you able to follow the steps in the demo outlined here? If not, what step caused the problem?
I cannot open the model that you attached to this forum. Windows throws an error and says the .zip file is empty.
Alexandra V
(5,680 Views)
Hi Alexandra,
The link you gave me talking about color shading, i need to rotate the 3d model by the x,y,z point according to the channels.
I would like you to take the data and the model and rotate the model by the data and send me this.   i send you the model again.
http://www.2shared.com/file/AmZJ_KCp/MQ-1_Predator.html
(5,678 Views)
Hi OzShimon,
DIAdem does not have an option to programmatically rotate a 3D model. The only way to change the orientation of the model is manually, by clicking and dragging or scrolling.
If you would like some help developing your application, we have a number of great Alliance Partners who are happy to develop code or tests for you.
Alexandra
(5,663 Views)
Hello Alexandra ,
I want to be sure...there is any way to demonstrate rotation of 3d or 2d object according to x,y,z coordinates?
thanks
(5,638 Views)
Hi OzShimon,
The only way to rotate any model in DIAdem is to do so manually. There is no way to programmatically rotate the model using a script or the data itself.
Alexandra
(5,624 Views)
