DIAdem
Sync LabVIEW data with Diadem
Is it possible to view data being acquired through LabVIEW VI (and logged to a tdms file) in Diadem at the same time?
We are acquring vibration and gps data using  a LabVIEW VI and want to display it on a map, updated as the data is being acquired in real time. Is this possible? If yes how? If you have some other alternative ideas, please share them as well.
Thanks and a great day to you
(3,640 Views)
Hi Rashid,
Well, this sort of works.  You can at any time reload the Data Portal from the TDMS file your LabVIEW code is streaming to, and this will update your display in VIEW, but there's no easy and automatic way of reloading.  The easy way is to have the user request an update, and we can make that a single icon click in VIEW.  The hard/automatic way would involve setting up invisible DIAdem workers-- I've seen that before, but I don't know how to do it myself.
Brad Turpin
DIAdem Product Support Engineer
(3,605 Views)
