DIAdem
TDM C DLL undefined references
Hello!
This is my first time trying to use NI tools or software and I'm trying to experiment with writing TDMS files. I downloaded the TDM C DLL from the website and tried to run the writeFile.c example without any changes, but I keep getting undefined reference errors (see attached picture).
This was after moving the nilibddc.h and contents from dev/bin/64-bit into the samples folder so that they were in the same directory as writeFile.c. Is this a configuration issue or what else could I be doing wrong? Any advice is very appreciated!
(1,334 Views)
Accepted by topic author clu03
Did you link to the correct version of "nilibddc.lib". I guess you might have forgotten to link to that library. There are different versions of the library for 32 and 64 bit.
(1,268 Views)
This was it, I forgot to specify which library to link to. Thank you!
(1,253 Views)
