DIAdem
TDM C dll + MinGW
I want to use the TDM C dll with the MinGW compiler.
Are there known problems?
How to use it with MinGW?
I have always error code -6204 ( An unexpected error occurred in the library) if I call a function from the dll.
Could there be another problem with code -6204?
Thanks...
(5,625 Views)
Hi c.bacher,
Tell me, what exactly is a "MinGW" compiler?  Is this an alternative C compiler like Borland's Code Warrior, or is this a different language like Delphi?  Is it a compiler that supports object classes or more of a scripting language?
Brad Turpin
DIAdem Product Support Engineer
(5,598 Views)
MinGW is a port of the GNU Compiler Collection (GCC). GCC is used under linux and can be used with MinGW under Windows.
You need it if you want compile Qt project's on windows without VisualC compiler.
Does anyone know detailed informations about error -6204?
brgds
christoph
(5,583 Views)
hmm I am not the cygwin expert.
Can you post a C++ and makefile or an
exe compiled with Cygwin.
I have the environment but it would help me a lot if I just have to debug
ready code.
Andreas
(5,542 Views)
I tried to run the simple writeFile.o example and it works.
I attach the sample and makefile I used.
I only had to include
#include "mingw/_mingw.h"
and thats it.
So could you give a more detailed description when the error happens?
Did you make sure that the content of the bin folder was in your exe folder?
(5,532 Views)
Sorry for the late answer,
in release mode it works. In debug not!
That's was the solution....
(5,520 Views)
