DIAdem
TDM Excel Add-In Automation for multible files
i use the TDM Excel Add-In in a Excel VBA Project. I am able to load, proceed and close tdm-files. Is there also a solution to load multible files (like MultiSelect = True)?
Thank you very much
Udo
(3,510 Views)
Hi Udo,
unfortunately the TDM Excel Add-In doesn't support loading multiple TDM/TDMS files at a time.
You may consider using DIAdem for working with multiple files or concatenated loading.
You may also try DIAdem 2017 beta which allows writing data back to XLSX in exact the same format as the TDM Excel Add-In does. This may allow to get the best of both worlds.
(3,486 Views)
I made some LabVIEW code that can convert multiple TDMS files into Excel files using the Add-In.  I know this is a DIAdem subforum but the code in there might help, or could even be built into an EXE that just gets ran.
http://forums.ni.com/t5/Community-Documents/TDMS-to-XLSX-Conversion/ta-p/3511652
(3,455 Views)
Thank you very much
(3,447 Views)
