DIAdem
TDM and TDX Reference Error
I have recently tried to open a .tdm file and I get an error that "fatal error (80) :Unable to open" the file name  and ":(The system cannot find the file specified.)"
I understand that the file name tdx needs to point to file tdx but the file the tdx is trying to reference is in the location it should be.  ANy ideas?
Tim
(6,054 Views)
Accepted by topic author smoothdurban
I was able to figure out what the issue was.  Someone had changed the filenames to both files and I was able to open up the TDM file in Notepad++ and change the reference location/name.  Worked like a charm.
Tim
(6,051 Views)
datafilerename "C:\temp\example.tdm", "C:\temp\example2.tdm"
This DIAdem command can be used to rename both files and update the content of the tdm header.
(6,043 Views)
