DIAdem
TDMS Data Logging - Waveforms & XY data
Hello Everyone,
I am measuring data of two different types of data
1. Waveform (t0, dt, Y)
2. XY graph (timestamp [array], Y[array])
My use case is:
1. Channels (10 channels) with waveform data has sample rate 1kHz, which acquire data as waveform. (DAQmx AI channel)
2. Another channels are (100 variables) OPC-UA based, which acquire data on event, and returns data in timestamp & value format.
OPC-UA variables changes its value very rarely.
3. I don't want to convert OPCUA data to waveform, since it will acquire more space.
I want to log both data in same TDMS file & analyze/veiw in DIAdem.
How should i achieve this?
BR & Stay Healthy,
Aniket Ramesh Gadekar
(3,007 Views)
Hi Aniket,
I suggest you put your 10 waveform channels into one group in the TDMS file, then create a new group for each separate X=Time channel that you have in your XY channels.  In the simplest case that all 100 Y channels use the same X channel, then that would give you a second group with one X=Time channel and all 100 Y channels in it.  In the most extreme case that would result in 100 groups with exactly 1 X channel and 1 Y channel in them each.
In LabVIEW you can easily append X values and Y values one at a time to the respective channels in the group(s) after the first one, as they appear on the OPC bus.
Brad Turpin
Senior Technical Support Engineer
(2,946 Views)
Hello
              AI Channel 1
              AI Channel 2
(2,934 Views)
