DIAdem
TDMS error -2511 Offset Too Large
I'm having the same problem as this thread http://forums.ni.com/t5/DIAdem/TDMS-error-2511-Offset-Too-Large/m-p/2960877.
How do you remove the last segment of the file if the file won't open in DIAdem?  Do you need to write something in LabVIEW?
Message 1 of 8
(5,772 Views)
Hi faustina,
You can indeed manipulate TDMS files in LabVIEW using the TDMS API (linked below). Do you have access to LabVIEW?
However, if part of your TDMS file's header is missing, it's possible that the file could be damaged or corrupt. Were you able to try the workaround suggested by brandonj in that thread of editing the TDMS file in NotePad++?
TDM Streaming VIs and Functions: http://zone.ni.com/reference/en-XX/help/371361N-01/glang/tdm_streaming_functions/
Tom D.
Staff Software Engineer
NI
Message 2 of 8
(5,742 Views)
working on resolving via brandonj solution.  Need application, however, do not have priviledges to load on our computers.  Getting permission is taking a LONG time.
Message 3 of 8
(5,666 Views)
Hi faustina,
It's possible that your .tdms_index file is corrupt, instead of the .tdms file itself. If it will take a while to get NotePad++ on your computer, one thing you can try in the meantime is to move the associated .tdms_index file to a different directory. Then, the next time you open your .tdms file, a new .tdms_index file will automatically be generated.
Just make sure you don't delete the original .tdms_index file such that you won't be able to recover it.
Tom D.
NI
Message 4 of 8
(5,653 Views)
LabVIEW cannot open the file (TDMS Open File function) therefore no index file is created.  DIAdem does create a new index file.
Message 5 of 8
(5,650 Views)
but it still cannot open the file
Message 6 of 8
(5,649 Views)
Hi faustina,
So, that means the problem is most likely with the .tdms file, and not the .tdms_index file.
You mentioned that you are seeking download permissions for Notepad++. Are you constained from downloading all software on your computer? There are also some hex editors available which could potentially be of use.
Alternatively, is there any way you can move the corrupted .tdms file onto another computer where you have permissions to download any editing software, or is the file totally confidential?
The white paper I have included a link to below will be of use if we can get to a point where you are at least able to view the contents of the file.
TDMS File Format Internal Structure: http://www.ni.com/white-paper/5696/en/
Tom D.
NI
Message 7 of 8
(5,635 Views)
due to new security policies, only certain individuals are allowed to load new software on any of our computers.  It's really frustrating.  I've concidered downloading the appropriate software to my home computers, but I can't remove the data file in question from work.
So I'm in a holding pattern until someone above me want's this done ASAP.
Message 8 of 8
(5,623 Views)
