DIAdem
Tdms file error
I am getting the error while trying to load .tdms file in the diadem 11.1. Attached the data as well as the error screen shot for reference.
X Ignatius
(2,164 Views)
Accepted by topic author Igni
Looks like your DIAdem installation is broken.
If the main TDM plugin is missing only few things will work.
Does this have a story before.
Potentially you need to reinstall.
(2,108 Views)
Hi Andreas,
Thank you very much. I had re-installed and found working.
X Ignatius
(2,045 Views)
