DIAdem
Text Array to Numeric Channel
I have a text array variable (with numbers) that I would like to end up as a numeric channel and I cannot figure out the most efficient way to do this - I suspect there is a great solution that eludes me.  I can use ArrayToChannels, but this creates a text channel.  Can I use ChnCalculate to convert a text channel to numeric somehow?  I have tried a few things, but nothing has worked yet.
My example:
Dim NewArray, NewChns
NewChns = "NewChannelName" : NewChns = Split(NewChns, "|")
NewArray = "1|2|3|4|5" : NewArray = Split(NewArray, "|")
Call ArrayToChannels(NewArray, NewChns)
' Results in text channel
Message 1 of 8
(5,622 Views)
Hi Julia,
here is a brute force solution:
Dim i
For i = 0 To UBound(NewArray)
  NewArray(i) = CDbl(NewArray(i))
' Results in numeric channel
May be that helps,
Christian
Message 2 of 8
(5,618 Views)
Hi Christian,
Thanks for the speedy reply - unfortunately that is very similar to what I am already doing, and I was hoping for something better.  But if this is the only way, this is how it will have to be!
Thank you again,
Julia
Message 3 of 8
(5,617 Views)
Obviously, it is sufficient to set the data type of the first array element to double:
NewArray(0) = CDbl(NewArray(0))
Christian
Message 4 of 8
(5,611 Views)
That works!  Thanks again 🙂
Message 5 of 8
(5,608 Views)
Hello Julia!
Another aproach is to convert the text channel into a numeric channel via DataBlClpCopy/DataBlClpPaste. The numeric target channel must exist.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 6 of 8
(5,603 Views)
Hi All,
Another possibility in DIAdem 10.1 or later is to use the new ChnCalculate() command:
Call ChnCalculate("Ch(""[1]/Name"") = CDbl(Ch(""[1]/Name"")))
But I think Christian's suggestion is the most efficient,
Brad Turpin
DIAdem Product Support Engineer
Message 7 of 8
(5,579 Views)
Hello Brad!
Can you guarantee that Christian's second version will work in future DIAdem versions?
Matthias
Matthias Alleweldt
Twigeater?
Message 8 of 8
(5,575 Views)
