Hi Bohm,
Yes this was hard to understand. The upcoming DIAdem version will have the following note in the help:
Note: You cannot use DIAdem commands in the Script DAC driver. You only can access DIAdem variables in the read mode. To do so you must declare the DIAdem variables using Dim, in the global section of the script. DIAdem then copies the current contents of the DIAdem variables onto these script variables.
Thank you,
Ralf
