DIAdem
Time/Date format for in Text DataPlugin Wizard
Can someone please tell me how to handle a time/date format in the Text DataPlugin Wizard with a timestamp like this: 09:40:00 Fri 08/06?
I've tried hh:mm:ss www but it doesn't yield the needed result. Also, I am not sure how to handle the spaces.
Jim
(3,082 Views)
Hi Jim,
DIAdem has a corresponding datetime format for that "Fri" component, but the DataPlugin api does not.  If you're willing to post or send me a sample data file, I can see how much effort it would be to create a VBScript DataPlugin from scratch-- the wizard will not succeed with this datetime format, but it is possible to parse this with VBScript.
Brad Turpin
Principal Technical Support Engineer
NI
(3,055 Views)
Hi Brad,
Here is a simple example file. Is it possible for the DataPlugin to be done in Python instead of VBS?
Jim
(3,034 Views)
Hi Jim,
Here's a VBScript DataPlugin that reads the one data file you posted.  I'm faster with those than python DataPlugins still, and I hope you'll agree that the source code is impressively simple, due to the VBScript DataPlugin helper objects.
Sub ReadStore(File)
  Dim j, jMax, Delim, Block, Group, Channel, ChanNames
  Delim = ","
  File.Formatter.Delimiters = Delim
  File.Formatter.LineFeeds = vbCRLF
  File.Formatter.TimeFormat = "hh:mm:ss Fri MM/DD"
  Set Group = Root.ChannelGroups.Add(File.Info.FileName)
  ChanNames = Split(Delim & File.GetNextLine, Delim)
  jMax = UBound(ChanNames)
  Set Block = File.GetStringBlock()
  FOR j = 1 TO jMax
    IF j = 1 THEN Set Channel = Block.Channels.Add(ChanNames(j), eTime)
    IF j > 1 THEN Set Channel = Block.Channels.Add(ChanNames(j), eR64)
    Call Group.Channels.AddDirectAccessChannel(Channel)
  NEXT ' j
End Sub
Brad Turpin
NI
(3,021 Views)
Thanks Brad!
(2,983 Views)
