DIAdem
To put two z-axis in a 3d graph.
hi ,
I want to draw a graph like an example.
I need two z-axis and want to know how to add them.
Please explain if there is another way to draw like this example graph.
(1,839 Views)
Hi sally,
In DIAdem you can overlay multiple 3d graphing layers, but there is only ever 1 X axis, 1 Y axis and 1 Z axis.  Do you really need to see multiple Z axes, or would it be sufficient to see multiple 3d surfaces on the graph?  The only workaround is to overlay a second 3d axis system and paint most of it invisible-- that can give you the appearance of a second Z axis-- but only if you never rotate the 3d graph.
Brad Turpin
Principal Technical Support Engineer
NI
(1,800 Views)
Thank you.
I'll try as advised.
(1,774 Views)
